Question regarding suspension
Old Sep 19, 2013 | 06:25 AM
WacoTXJeeper's Avatar
Default Question regarding suspension
New to jeeps. Will rubicon or sahara stock suspension parts fit a 2008 2 door stock height wrangler X? I am not looking to lift my jeep right now, but am looking for better suspension and a more comfortable ride. I love my jeep and how it rides, but when I hit little bumps in roads it seems my jeep over exaggerates the bump and makes it feel like I ran over a speed bump at 50 mph lol. I have a buddy who has a sahara and it is much smoother on the same roads, and his jeep is all stock as well. Or does it even matter at all?
Old Sep 19, 2013 | 07:03 AM
Turbo's Avatar
For what you are describing I would think your air pressure may be to high, Your shocks may be bad or you may have smaller tires than your friends Sierra. I believe the Rubicon or Sahara parts will fit but that may not fix your problem. Good luck to you.
Old Sep 19, 2013 | 07:13 AM
TheDirtman's Avatar
Yes you can swap parts from between models. The only difference in the coils is the weight rates. A 2 door soft top will have a softer rate then a 4 door hard top. The shocks on the x model are crap. You might want to look into a old man emu or an adjustable from ranchero, they both have good reputations for a good ride. I would also agree with the tire pressure, most will run run +-28 psi
Old Sep 19, 2013 | 07:48 AM
Thank you for the information. My tires are the standard Goodyear wrangler highway tires with 17" wheels. The psi max is 44 but I keep the around 30 psi. I'm thinking of going with aftermarket shocks and I've heard the Ranchero brand is pretty good.
Old Sep 19, 2013 | 08:00 AM
AlexjeepVb's Avatar
Yea I would look at some new shocks, not worry about the springs, maybe some bilstiens would be nice
Old Sep 19, 2013 | 10:06 AM
I'll have to look those up. I want quality but nothing very expensive haha
