Questions about backspacing
I was looking at getting some different rims and I found some with as little as 1" of backspacing. Is that too little or should I go with a rim that has more?
Check the FAQ's at the top of this modified area.
Stock rims have a 6.25 BS. Generally, a 4.50 or so would be a good starting point, depending on what size tire you are moving to.
Your stock moab wheels have 6.25'' backspacing
If you upgrade your tire to 12.5 wide you will need to decrease backspacing to 4.5-4.75'' to push tire outside
I'm not sure what a 1" BS would look like. I picture the wheels sticking 3-4 " beyond the flare. I have a narrower wheel (16x8's) with 4" BS and it sticks about 1/2" out from the flare. I'm not sure of the answer for you. What wheel is it?
Will this put stress on the studs?
Or am I looking at it wrong?
