Questions About Reducing Lift Height
Updated Below
Hey folks, I've got a quick question I'm hoping you can help me with. My JKU came with a Rough Country 3.25” lift kit (link below for reference) and I'm thinking about changing it. The kit comes with lifted springs and 0.75” coil spring spacers that go between the springs and stock coil isolators.
If I wanted to reduce the height of the lift, couldn't I simply remove the spacers that come with the lift? If so, then I suppose I'd need to make any needed adjustments to the geometry? Unfortunately, I think my current Rancho 9000XL shocks are for a 3-3.5 inch lift. I may also reach out to the manufacturer, but I'm curious if this is an option.
Rough Country 3.25” Lift
If all the other components are set up correctly - aka toe, TB angle, caster, bushings nice and solid and diff angles - then there is not a lot of advantage to reducing the lift unless you want much smaller tires than at present. Bump stops should help you protect shocks from bottoming out.
Measure the caster prior and if it is near 4.5+ then it will be about 5+ when you are done removing the 3/4". I would leave it at that. Or you can turn the LCAs in by 1/2 thread to get back to where you were. If I were doing the job I would go the droop route by lifting and let the springs come loose then remove the spacers.
Listen to Sixty4X4 , block up the frame and droop the axle low enough to remove the spring, by far best and only way to do it. Block up one axle at a time no need to do both front and rear at the same time. Why would you need an alignment? what's going on in the rear that would make you want to adjust the rear lower control arms?
I mostly mentioned that I have them if I need to make adjustments. I previously had a pinion correction made on the rear end since it was dipped down from the lift. If I go ahead with this, I'm not sure if additional corrections (or a correction to the previous adjustment) will need to be made.
On the JKU wheelbase, the factory rear DS is very forgiving as it has CV joints on both ends. Most won't do any rear adjustment because of the pinion angle. Where rear arms typically enter the picture is being ~3.5" and going up to 37s, cuz that tire creeps so far towards the front of the wheel well that you want to extend the wheelbase back out again....not to mention it just looks funny at that point. If you change the height, and if you have the ability to do so, then you may as well tweak things so the rear pinion is ideal, but it's probably not the end of the world either way.
Quick follow up question: if I have had the axles centered previously with my adjustable front/rear track bars, would it be necessary to have this re-checked after I perform my "lift reduction surgery"? Or would 0.75" not change things much, if at all?
