Questions about upgrading coils, shocks.
Old Feb 18, 2018 | 07:42 PM
GGJKU's Avatar
Default Questions about upgrading coils, shocks.
I currently have a 2.5" rough country spacer lift. Looking to upgrade to Synergy 3" front and 2" rear coils. I have all component neccessary, but my issue is I revently upgraded to new Bilstein 5100's for 1-3" lifts. The 2" rear coils typically give around 2.5" of lift, and the front 3" coils typically give up to 3.5". Id rather not spent more money than I have to, so i'm wondering If I replace my front shocks with 3.5-5" Bilsteins, and continue to run the 1-3" Bilsteins on the rear, will it cause any issues?
Old Feb 19, 2018 | 04:40 AM
TrailBadger's Avatar
Former Member
I'm unable to inform you about the Bilstein shocks as that I've never had a set before, However it would be best to contact Bilstein and ask about what shocks would best be suited for your amount of travel needed in order to achieve the best articulation of your shocks.
I've done the same with the TJM shocks as their general manager sent me a detailed list of those shocks best suited for our build.. Here's the numbers the General Manager of TJM selected for our 1.5 inch suspension upgrade.
Front- 650GEL136X (TJM Long Travel-50mm)- Front 630 extended & 380 collapsed
Rear- 650XS236Z (TJM Stock-40mm)- Rear 560 extended & 350 collapsed
Check with Bilstein for numbers like this based on your current setup.
Old Feb 19, 2018 | 03:41 PM
TheDirtman's Avatar
It should not be an issue but you can always install the coils with your current shocks and drive around on them for a week or so to let them settle in and then take some measurements so you can size them for your set up. Bilstein has their lengths listed on their website for reference.
Old Feb 19, 2018 | 04:21 PM
jadmt's Avatar
JK-Forum Ambassador
Billys for 1.5-3 lifts are fairly short ie 15.3" -25" for rears and 15" and 24.6" for front so you will be fine you just won't get max droop up front. you will be able to get by with minimal bumpstop. If you have the shocks run them until you want more.
Old Feb 19, 2018 | 05:27 PM
nthinuf's Avatar
He wants to swap to the 3-5" length shocks up front. (27.56 / 16.41 / 11.15 travel)
As was mentioned in your other post on this, check the brake and abs lines, you might see about disconnecting them from the mounts to get more slack, or maybe look at brackets or new longer lines. Also make sure that the new bumpstops are tall enough to keep the longer shocks from over-compressing. And though unlikely, check that the coils don't fall out at full extension.
Old Feb 19, 2018 | 07:26 PM
jadmt's Avatar
JK-Forum Ambassador
dang I need to go back to reading 101 lol. I totally missed the last part.
Old Feb 22, 2018 | 02:21 PM
GGJKU's Avatar
Thumbs up
Hey all, spoke to a Bilstein tech and he recommended I run the 3-5" 5100's in front and keep my rears. Went ahead and ordered the coils, bump stops, two front shocks, and an exhaust kit for the hell of it. Gonna measure out the shocks once I get the new coils on and see how it all fits together. Will let you all know how it goes after I spend all day Sunday with my buddy throwing it all on.
