quick answers needed now!
Old Oct 20, 2011 | 06:36 PM
jtjk's Avatar
Default quick answers needed now!
i am trying to put my axle shaft back in but it just wont go. it slide in, then a bit more (through the inner seal i think) but then nothing. i can turn it a little to the righ and left but no more than that.
i have read and people seem to say it just slides in. i have been trying to just slide it in for 2.5 hours now and am lost for an explanation.
please help before the frustration leads me to dowse this motha in gasoline and burn it to the ground
Old Oct 20, 2011 | 06:40 PM
jeeeep's Avatar
did you pull both out? if so, try swapping sides -
Old Oct 20, 2011 | 06:43 PM
jtjk's Avatar
initially yes. the other one is now reinstalled
Old Oct 20, 2011 | 07:02 PM
jtjk's Avatar
bump for an answer
Old Oct 20, 2011 | 07:17 PM
jeeeep's Avatar
try rotating the opposite side just to try and align- it should slip in, did you grease it first?
Old Oct 20, 2011 | 09:08 PM
MikeReo's Avatar
front or rear? make sure the seal or race isnt mangled and walk away if your getting too frustrated. it'll go but the last thing you want to do is break something just trying to get it in there
Old Oct 20, 2011 | 09:34 PM
jtjk's Avatar
its the front. when i slide it in i can feel it slip over the seal so i dont think it mangled. it gets about an inch from being in and just stops. i can turn it an feel it rub against a groove, iv tried wriggling it, propping it up, spinning the other tire, turning the steering wheel. turning the drive shaft. nothing seems to work.
i would normally just walk away but i have a carport and my nbrs are freaking out that this things is sitting there without wheels.
Old Oct 20, 2011 | 09:43 PM
MikeReo's Avatar
stock shaft right? otherwise i'd say make sure the aftermarket shaft is the same length and spline count as the oem shaft your replacing. You gotta kinda lift it in . The end your holding needs to be a bit lower than the side your pushing in...
