Which quick disconnects?????
I've used a variety of QD's...and the JKS QII's are the best by far, esp, because you can fine tune their length over a large lift range....extremely useful, and, because you can get them on/off very easily compared to some of the others, and, they don't rattle...and are very well made.
The Teraflex ones don't rattle, and are not too hard to get on/off IF your lift height, the tilt of the terrain, and their lengths match up, otherwise, you have to lean on the truck, and rock, and so forth, to get them back on. They are very well made.
The others, well, they rattle, and are hard to get on/off under most conditions, compared to the JKS QD's. Some, like Warrior, have broken/not been as durable.
Hope that helps!
Hope that helps!
http://www.currieenterprises.com/ces...t.aspx?id=2953
The currie makes it so you're still wishy washy on the road, and you're not completely disco'd off road...sort of a compromise...that doesn't work as well as a QD on or off road...but, is more convenient.
The JKS and Teraflex both have a second pin so you can just clip the bar up out of the way when disco'd....I believe the others give you a velcro wrap for it, etc.
I had the Full Traction discos that came with my lift and hated them. Could they have made it harder to use? I had to use a hammer to get them on and off....
I bought the JKS quicker discos and haven't looked back. They are so incredibly well made, quiet, and easy to use its a no brainer.....
