quick disconnects
then what do you do with the swaybar? bungee it up? Even if I went with JKS or a different brand, I would go with the teraflex retaining brackets. They require no drilling, cause the brackets just go under the nut on the front body mount bolt (under the core support). Installation take 5 minutes. 5 Minutes!!! That is not an exaggeration. When you disconnect you just pull the pins, swing the bar up, slide the discos on the retaining brackets and put pins in. Thats it. No bungees or anything. I love it.
Lots of people like the JKS and swear by them, but like I said before I just don't get how they are better than the Teraflex...I would definitely recommend the Teraflex discos though, more practical and less expensive.
I'm running JKS disconnects with the Teraflex mounting pins. Have the passenger side one
a little longer than driver side to help with the "Jeep learn to the right".
