Quick Franken lift ?
Old Apr 7, 2010 | 02:11 PM
jdmda9noke's Avatar
Default Quick Franken lift ?
Right now i have a RC 2.5 spacer lift
instead of taking it off and buying a new "bigger" "better" lift, is it possible to leave it on and buy the teraflex 2.5 coil lift and add it too it??
if so i know ill need:
Longer shocks
sway links
Upper control arms for caster (??)
track bars
Bump stops
Please someone chime in if theres other things needed or if this wouldnt work as an option
Thanks Bryan
Old Apr 7, 2010 | 02:19 PM
mkjeep's Avatar
The tf 2.5 will give you 3in of lift, that'll put you at 5.5in of lift, you need a whole lotta stuff.
Old Apr 7, 2010 | 02:33 PM
jdmda9noke's Avatar
whats the lift limit on a Unlimited 6speed before new driveshafts are needed?
Old Apr 7, 2010 | 03:01 PM
dlincoln91's Avatar
it depends on a 2 door 3 inches of lift will do both the front and rear i beleive on my 4 door i have a 3 inch teraflex and have ripped the boot on the extension part of my driveshaft and plan to replace it very soon
btw its my front driveshaft that the boot is torn
Old Apr 7, 2010 | 04:08 PM
nthinuf's Avatar
The Faq's are generally a decent place to start...
Q: What are all the components that I will need with a 4" lift?
Q: What is Caster? How much do I need?
Then move on to the DIY alignment write-up.
