quick help with driveshaft installation
JE Reel OE replacement driveshaft. The stock front DS has 8 small bolts with retainers between every two bolts. The new JE reel shaft came with replacement bolts. I figured I should use the replacement bolts, but should I use the stock retainers that go between each pair of bolts?
Unfortunately, I already have it installed without them, but before I install the rear, I want to make sure they are or are not needed!
Thanks for the input.
