Quick Question...
Old Jan 11, 2012 | 02:24 PM
cmvanbibber's Avatar
Default Quick Question...
Im planning on getting the Rustys 3.25 long arm kit, 1" More body lift, and 1.75 Coil Spring spacers, is that enough lift for 37" without new finder flares?
Old Jan 12, 2012 | 06:36 PM
thanks for answering guys, its appreciated
Old Jan 12, 2012 | 06:42 PM
Robar's Avatar
You can run 37s with a 4" lift, so you could probably do without the spacers or the body lift.
Old Jan 12, 2012 | 06:43 PM
FoxRacingJMC's Avatar
More than enough... just make sure you have the correct backspacing on your wheel as well.
Old Jan 12, 2012 | 07:40 PM
jonboy's Avatar
Doesn't the rusty's 3.25 kit come as 2.5" springs and 3/4 spacers? Meaning it wouldn't be a good idea to stack the 1.75 and 3/4 spacer.... I don't know first hand on the particulars of that lift.
Old Jan 12, 2012 | 08:35 PM
atomthompson's Avatar
A fellow jeeper out here is running 37's on a TF 2.5 lift with a 1.25 body lift. In theory you could pretty much run them with no lift if you put in huge bumpstops. Haha. You should be fine without spacers or the body lift. I'd test them out with just the lift and then go from there.
