Quick Question!
Old Nov 2, 2012 | 02:49 PM
brizon85's Avatar
Default Quick Question!
ok so after I had my rubicon express lift installed I got underneath to inspect the work. I ended up staying underneath my Jeep for some time transfixed because of how cool it looks. Anyways I noticed that my rear coil springs both have a slight bow to them. Is this normal settling or are they simply bowed in general?
Old Nov 2, 2012 | 05:05 PM
gunbo75's Avatar
Do you have pictures. That wood really help and what size lift did you go with.welcome to The forum
Old Nov 2, 2012 | 05:53 PM
k0260's Avatar
If your lift came with shorter rear lower control arms to help correct the pinion/drive shaft angle, this will cause the springs to bow, it's no problem. With my 3.25 inch lift and shorter rear lower control arms my springs bow too.
Old Nov 2, 2012 | 06:11 PM
dinojeep's Avatar
A little bowing is normal. You can install correction wedges to help.
Old Nov 2, 2012 | 06:51 PM
brizon85's Avatar
ok was honestly just curious. The jeep is level front to back with no visible sag. it's a 3.5 in rubicon express standard lift with all stock control arms.
