Quick Question on back spacing
Old Aug 3, 2011 | 07:43 PM
mlax's Avatar
Default Quick Question on back spacing
Want to pull the trigger on wheels and tires for an 11 JK. I am looking to run 16x8 wheel with +10mm offset and/or 4.92 back spacing. The tire will be LT285/75R16 with dimensions of 32.8x11.2. I will be adding the TF leveling lift prior to installing the tires. Will this work? Do I need to be concerned with any rubbing issues? I have read so many threads but they all have different responses. Please help!
Old Aug 3, 2011 | 08:19 PM
wayoflife's Avatar
JK-Forum Founder
it'll be tight but, you should be able to make it work. you may see some minor rubbing at a full turn.
Old Aug 3, 2011 | 08:23 PM
mlax's Avatar
Is there a better suggestion? Should I go with a larger lift or just look for another rim with a different backspace (less than 4.92)
Old Aug 3, 2011 | 08:24 PM
wayoflife's Avatar
JK-Forum Founder
lift won't make a difference, back spacing will. 4.5" is a good size and what i normally recommend. 4.92" is close and i would think you should be okay.
Old Aug 4, 2011 | 02:45 AM
BIGCHRIS's Avatar
I ran that tire on a stock steel rim, I think the stock is 6.5 backspacing and I used 1.5 spidertrax spacer giving it a total of 5 inch and it worked great no rubbing at all. just to be sure do a serch on the stock 16" steel and make sure I'm right about the 6.5 and you can work with that
Old Aug 4, 2011 | 03:32 AM
mlax's Avatar
Thanks for all the help. I had these all set up in the cart ready for purchase and got cold feet. I don't want to spend that kind of money and have them not fit.
Old Aug 4, 2011 | 04:32 AM
Cpt. Flapjack's Avatar
I run a +10 offset wheel and 35x12.5s. I have just a little rub at full flex with wheels turned to the stops. Not enough to feel, but the paint is rubbed off of the 90deg bend in the swaybar. When I ran my 285-70-17s, I had no rub at all.
