Quick Question on swaybar disconnects/end links
So I'm looking at finally buying my 3" Zone lift, but it doesn't come with disconnects for the front sway bar. Feel kind of dumb for aksing, but, Zone website, they have available "front swaybar end links" and the JKS Quicker Disconnects.
What is the difference between these 2? Do they both just keep the swaybar connected? If I get the JKS Quicker Disconnects, I don't need the front swaybar end links, correct?
Alot of kits out there send you longer links for the rear and have you move the rears to the frt. Don't know if this is the case with the zone lift or not. But a reg frt link will be bolt on , the jks quick discos enable you to quickly disconnect the frt links from the swaybar. To answer your question in short, get quick disco's over reg frt sway links.
x 2 - you will want quick disco's for the front. I have the JKS 0"-2" disco's and they have worked great. They also make a 2"+ set that allow you to adjust with a higher lift.
The only drawback is that you must remove them all the way when you disconnect them. The Teraflex quick disconnects are designed to remove one half of each side and then attach them out of the way - a little nicer so you don't have to take them off and store them in the vehicle somewhere. Overall they are both good designs!
