Quik Locker question?!?!?!
Just wondering.... I just bought the superior 4.88 gears for my JK with a front Dana 30 and the rear Dana 44.
I want to buy the Aussie locker for the front diff. Will it fit?? I also will be using a Riddler Diff cover. Will it Fit??
Also which one do I get for the rear Dana 44?? NO ARB!! cant afford it. I'm lookin for the best VALUE. I also need to know if it will fit with the Riddler Diff Cover.
Thanks guys!!
Thanks guys!!
Thanks guys!!
Thanks guys!!
THere are several people here on the forum running the Aussie without issue. I have one myself but I've not installed it yet. My understanding is, in odred to get the clearances right, you have to use TJ side gear thrust washers. Some have installed the Aussie with the JK thrust washers and not had issues at all. Must not be too critical. I'm going to install and measure mine and if it's close, I'm runnin it.
THere are several people here on the forum running the Aussie without issue. I have one myself but I've not installed it yet. My understanding is, in odred to get the clearances right, you have to use TJ side gear thrust washers. Some have installed the Aussie with the GK thrust washers and not had issues at all. Must not be too critical. I'm going to install and measure mine and if it's close, I'm running it.
Just as an FYI, i was the first one to put the TJ Dana 30 Aussie in the JK Dana 30 (according to Aussie). It fit perfect, and all clearances were perfect. I have 20k miles on it and drive it hard on the trail, again...perfect.
Hope this helps.
Hope this helps.
