Quoted $400 to install a Truetrac?
Old Jun 12, 2014 | 12:49 PM
300xc's Avatar
Default Quoted $400 to install a Truetrac?
There is one major offroad shop near where I live, that I have been recommend to go to on several occasions for my 2010 Wrangler Sport. I was looking into limited slips, and I called this place. They said it would be a little over 4 hours of labor, plus bearings and whatever else they need. This is for one in the rear. Does that sound stupid high to anyone else?
Old Jun 12, 2014 | 12:56 PM
NUKEM-10's Avatar
I know when i got my gears installed it was around 900 for the gears and labor. So that doesnt seem to high if that includes the Truetrac.
Old Jun 12, 2014 | 01:02 PM
300xc's Avatar
That is just the install cost.
Old Jun 12, 2014 | 01:06 PM
nthinuf's Avatar
The average cost for a gear install is in the $1500-$2000 range. (gears + labor, out the door). It should be roughly the same labor cost for installing a full case locker/limited as it is for installing gears. And then add in the fact that the truetrac uses some very hard metal, and the installer may need to send it out to get it drilled.
Your quote is in the ballpark for the installation of a single truetrac, and may even be low depending on whether he is paying another shop to drill it.
PG-JKU's Avatar
The Truetrac replaces your carrier so basically they need to reset your gears as if you had a full re-gearing done, shims etc.
Old Jun 12, 2014 | 01:36 PM
LOST's Avatar
Sounds about right.
I paid just under $900 for a True trac parts and labor. Included Timken bearings as well.
If you planning on re-gearing might as well do them both at the same time, labor cost is the same.
Old Jun 12, 2014 | 05:55 PM
300xc's Avatar
Originally Posted by LOST
Sounds about right.
Ok good to know. I thought I read on another forum that installs were in the $250 range. I've read so much, I might be getting mixed up with the Aussie locker install prices. Would the Auburn Gear LSD cost about the same? I know that one uses a clutch pack, so I'm not sure if that makes a difference in installation, but I might as well ask. If they are about the same, then I will probably just wait and save up for an ected.
Old Jun 12, 2014 | 06:17 PM
nthinuf's Avatar
Lunchbox lockers fit inside the stock carrier, so the gears don't have to be set up again. Lots of people install these in their driveways in a few hours.
If you want a limited, stick with the truetrac.
http://www.eaton.com/ecm/idcplg?IdcS...Name=CT_139762
Here is a decent locker over-view:
Project-JK.com - Jeep JK Wrangler Resource » Dynatrac Presents - Lockers 101
I think that the d44 e-locker being upgraded to a 4-pin design is the only update since this was made.
Old Jun 18, 2014 | 02:02 PM
NUKEM-10's Avatar
Nope thats gears too. They were running a special for $1000 and i showed up with $900 cash, and they did it and i still get the warranty too.
Old Jun 19, 2014 | 02:16 AM
Mark Doiron's Avatar
It isn't clear if that includes the bearings, and what particular bearings they mean. They typically go for $100 and up for a master rebuild kit (usually recommended).
