Rack Height
Hi folks,
I'm in the market for a rack (08 Rubicon 4dr) but I have space issues in my garage. With the 2.5" lift and my 35" tires I only have about 5" of clearance through my garage door. So the question is, which rack is the shortest and has the lowest profile?
Thanks!
Thanks!
Hi folks,
Thanks!
Thanks!
Gman*2007
Well, I went out and measured my Wild Boar rack for you.... Every Jeep is going to measure out a little differently due to different lifts, different tires, etc..., so I just measured from the highest point on the hard top (the tops of the middle directional ridges) to the highest point on the rack using a straight edge across the top bars of the rack. The highest point of the rack measured out to be 6" over the highest point of the hard top. To run this rack you would probably want 7" of clearance over your hardtop...6.5" at the very least and that would be a squeeze. I don't know what the shortest rack would be....but I measured mine just to give you an example.
