Rancho 2" sport lift 10K mile review
What is the number on the tag on the rear springs, by chance?
Hello Rancho
So here is my stock spring number.
I'm not really complaining as I feel I got the 3/4 lift the spacer was supposed to give.
I just wish the spacer would have been taller, perhaps 1 1/2.
I am considering getting some thicker spacers.
Then I'm worried that the shock won't be long enough. Rancho does make a RS9000xl for a three inch lift, don't you ?
Or will the shocks that came with the 2" kit work ?
Another option is to look for some rear springs with a larger number, say a 59 or 60. That will get you a bit more clearance.
A spacer is another option.
Your shocks are a-ok. These are what we use in our 3" system actually.
Hello Rancho
Attachment 598580
Attachment 598580
I swapped my light duty rear springs with heavier rears out of a jku and it worked out perfect and netted me an additional -/2-3/4 of lift. Much better load capacity too.
Hello Rancho
Attachment 598580
Attachment 598580
Rancho, is the front shock also what you use with the 3" kit? I'm thinking about moving up to 3" rancho springs all around. What do I need to accomplish this?
No the front shock is a shorter shock, don't forget on the newer Jeeps too much droop up front and the exhaust/driveshaft have to be addressed.
If you want to go to a longer shock
RS999329
But you still need to make sure bumpstops are the proper length, exhaust etc.
RS999329
Ok thanks and yes I suspected no less. Can you tell me what I will need to go from a 2" to a 3" sport system? I know I don't need the entire kit. Also, is the shocks I have up front good for a 2.5" kit?
See below and here.
For a 3" SPORT
New coils.
Track bar (front)
New front end links
Exhaust mods for 2012+
Correct size bump stop spacers.
Rear track bar bracket.
So a lot of "little" things.
For a 3" SPORT
New coils.
Track bar (front)
New front end links
