Rancho rs9000
Old Mar 19, 2017 | 07:16 PM
Horsebeater's Avatar
Default Rancho rs9000
Anyone running these shocks? I have them on my jk and they are rubbing the frame. What have you done to correct the issue? I don't want to get different shocks because I like the adjustability.
Old Mar 19, 2017 | 07:20 PM
pbeabout's Avatar
Metalcloak makes some brackets that would solve your problem.
Old Mar 19, 2017 | 07:57 PM
Those are nice! Thanks!
Old Mar 19, 2017 | 08:15 PM
karls10jk's Avatar
Nemesis industries makes a similar bracket. What you've got to watch out on is to note that the brackets typically move the shock up to where you lose uptravel and gain downtravel. An ideal combination would be those brackets (front and rear) paired with longer shocks for "stock" height.
Old Mar 20, 2017 | 04:21 AM
Canvas's Avatar
Veteran: Navy
Post up a picture.
I ran them for two years with a 3 inch lift and did not have an issue.
r/
Will
Old Mar 20, 2017 | 08:16 AM
shawnphi1's Avatar
Originally Posted by Canvas
Post up a picture. I ran them for two years with a 3 inch lift and did not have an issue. r/ Will
I have them too for over 2 years now and no rubbing issues here on my 2.5" RK lift
Old Mar 20, 2017 | 09:07 AM
Monte417's Avatar
X2 that's what I run
Old Mar 20, 2017 | 09:08 AM
Monte417's Avatar
When you are flex out the shock body will indeed contact the frame. Probably haven't noticed cause you have been in the vehicle when flexed out or never though to look
Old Mar 20, 2017 | 09:44 AM
Rancho's Avatar
Sponsoring Manufacturer
Is it happening on one side?
Old Mar 20, 2017 | 10:05 AM
Both sides
