Sponsored by:
Sponsored by:
Rancho RS9000XL shocks: I'm a believer
Old 10-15-2014, 12:56 AM
  #31
kjeeper10's Avatar
The 29/30xl shocks are somewhere around 1" longer compressed than stock (rubicon shocks)
With a small amount of bump stop you can run the 29/30's.
2007 Rubicon /2 door/6 speed
Old 10-15-2014, 06:03 AM
  #32
fredrok's Avatar
For you guys running the 9000s, have any of you loaded your rig up with a lot of weight (ie camping gear, etc)? My ride is great already w/ the 5100s but I'm considering these on the rear in hopes that increasing the firmness setting will help with tapping the bumpstops so much when loaded down.
Matt, et al ~ Can you get these with a black boot?
Old 10-15-2014, 06:17 AM
  #33
bevan7170's Avatar
Originally Posted by fredrok
For you guys running the 9000s, have any of you loaded your rig up with a lot of weight (ie camping gear, etc)? My ride is great already w/ the 5100s but I'm considering these on the rear in hopes that increasing the firmness setting will help with tapping the bumpstops so much when loaded down. Matt, et al ~ Can you get these with a black boot?
I've got these shocks on all four corners. I've normally got 200-300 lbs of equipment for work in the trunk and back seat all the time. I have them set around 5 on the adjuster and they handle just fine. If I was going to do it again I'd still go this route.
Old 10-15-2014, 08:14 AM
  #34
Sponsoring Manufacturer
Rancho's Avatar
Actually I have heard of guys running Mono's up front and the 9000's in the rear for towing. But you may still hit the stops, FYI. The boots on the rear shocks are a hard plastic boot but can be removed and replaced with a black boot. It can be a little tricky, FYI. The P/N is RS1952. It is a 9.5" boot.
Thanks!
Old 10-15-2014, 08:25 AM
  #35
ccfewell's Avatar
Want to order the 9000's and wondering which ones to order. Have a JKU running 2.5" coil lift with stock shocks on extentions currently. Any suggestions are appreciated.
Old 10-15-2014, 08:30 AM
  #36
Rancho's Avatar
Look to the
RS999329
RS999330
Enjoy!
You WILL not reuse the extensions.
Old 10-15-2014, 08:47 AM
  #37
ccfewell's Avatar
Thanks. And looking forward to deleting the extensions ASAP.
Old 10-15-2014, 04:43 PM
  #38
fredrok's Avatar
Bevan, Matt, thanks. I think I'll try them out once camping season rolls back around. I would expect it to still hit the stops but just hoping that they may provide enough resistance that I can cut that down a decent percentage.
Old 10-16-2014, 06:11 PM
  #39
MTMxRubi's Avatar
Just ordered mine. Can't wait to receive and install.
Old 10-16-2014, 08:19 PM
  #40
Sierra141's Avatar
Just ordered mine too has anyone received their visa pre paid card from rancho, and how long did it take?
Quick Reply: Rancho RS9000XL shocks: I'm a believer
