Randoms lights on dash
Old Aug 29, 2013 | 01:20 PM
mrlobaloba's Avatar
Default Randoms lights on dash
I have a bunch of random lights popping up on my dash. Anyone else experience this. I have a superchips installed.
Old Aug 29, 2013 | 01:45 PM
MojaveJK's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=493176"/>
Could have a bearing shot, I've seen that cause those lights in other vehicles
Old Aug 29, 2013 | 02:13 PM
Nick_Good's Avatar
More than likely a wheel speed sensor is shot.
Old Aug 29, 2013 | 02:22 PM
170-3tree's Avatar
scan or have it scanned. if it says wheel speed sensor circuit, it is that wheel that will need it replaced. oddly, I did three of these today on Chevy trucks.
Old Aug 29, 2013 | 02:47 PM
Robnasty's Avatar
Do they stay on? I have a 2012 and all of my lights blink and I hear a single chime every so often. My speedo and tach goto zero then back to their position. Doesn't seem to have a rhyme or reason on when it happens.
Old Aug 29, 2013 | 03:11 PM
13commandojk's Avatar
Mine came on briefly then went off.. i inspected everything and noticed the ground on my battery was really loose. Tightened it down, and problem free.
Old Aug 29, 2013 | 04:02 PM
Smashboogie 4x4's Avatar
Former Vendor
You should definitely have it scanned. That will point you in the right direction. If you get it scanned and need the code diagnostic procedure let us know.
Old Aug 29, 2013 | 04:19 PM
Ryan0260's Avatar
Is it while you are trying to install a tune?
Old Aug 29, 2013 | 04:28 PM
mrlobaloba's Avatar
I ve had the superchips installed for a while. I ll scan and see if any codes come up. I ll also check the battery and see if the cables are tight. Thanks everyone.
Old Aug 29, 2013 | 06:48 PM
onecrazyfuq's Avatar
I've had this for over a year I get c1210 g sensor low circuit. Looking into it. It could be the yaw sensor or clock spring. Lemme know how you make out
