rattling from rear brakes over bumps
Anyone have a rattle when going over small bumps coming from rear?
I originally suspected CA bolts or shock mounts but all were tight.
Then I tapped the rear calipers and they click/rattle.
Verified by going over the bumps while applying brakes and it doesn't make the noise then.
All anti rattle clips are in place also.
Sent from my LG-LS980 using JK-Forum
I could wiggle the bracket about 1/8" and make that annoying clicking
Pull the caliper and pads. Remove the pins from the caliper being careful not to tear the boots. Clean well with brake cleaner, repack the pin cavity with caliper grease (I like Super Lube synthetic grease) and make sure boot is reseated in grooves. If pads are still good, clean the ends and clip surfaces and grease with same. (make sure clips are not worn from lack of grease) Reassemble, no more noise.
gordysmithtwo@gmail.com (05-04-2021)
I have a 2012 Rubi unlimited and I have 73k lifted with 35's. I will be soon replacing the stock pads and such. Any suggestions as to pads calipers brands I should look at or stay away from?
If you want to move up to ceramic, this is the best deal I've seen Brake set
And of you like to spend more on the slotted rotors Brake set slotted
If you have even wear on the pads and all is working fine now, I'd leave the calipers alone.
Do follow the bed-in procedure well on any ceramic pad/rotor set up.
And as a suggestion, brake the bleeder screw loose to expel the fluid when pushing the piston back into the caliper instead of forcing the old, nasty fluid back through the system. Then top off.
