RC 2.2 shocks, why does it do that?
I spent awhile searching and could not find the answer to my little dilemma on the RC 2.2 strut, why does it not extend on its own? When installing it, you can push the strut in but it would need to be extended by pulling it out, I understand that the spring will pull the strut back out when its installed. Can anybody explain that because a normal strut would gradually extend on its own. My RC 2.5 lift was installed yesterday and have no issues yet.
was the shock brand new? I have never seen new shocks do that. They usually have wire around them to keep them collapsed so you can get them in place and not have to fight them extending.
I have never had RC parts so maybe their shocks are made this way but usually shocks do that when it is getting time to replace them. I have only seen old shocks that are worn out do that. If they are new I would call RC
brand spanking new shipped direct from RC. they were hard to push in and wouldn't come out unless I extended it by pulling them out... weird.
I was told that since they are Hydro shocks, they don't extend on their own. Gas-charged shocks (like bilsteins) automatically extend. I compressed my RC shocks when I removed them and set them in the garage--they never extended on their own.
-Adam
-Adam
Is it possible they sent you a 2.2 steering stabilizer by mistake? Those push in but don't spring back out and they look similar although they have an eye on the shaft end instead of a threaded end for front or the little tee bracket for the rear.
I would believe this. I didn't think about their "higher end" shocks not being nitrogen gas charged. If they are hydro shocks this makes sense. Hydro shocks are supposed to ride better than nitro shocks. Nitro shocks have a gas charge (that presses the shock open unlike the ones your have) and that has benefits for sure but shocks that are hydraulic without that pressurized charge are supposed to ride softer. Main problem I have ever heard with running hydro shocks is that they heat up and the shock generates bubbles in the oil and then the dampening of the shocks start to fade.
My new 2.0 Series have an incredible ride. We have alot of potholes here in central Illinois and these are a major improvement over stock for sure. I understand that they have a better feel than the 2.2 series according to the guys at RC. I would ask for a swap if you're not pleased.
