RC control arm relocation bracket install
Old Dec 27, 2012 | 05:32 PM
97bailee's Avatar
Default RC control arm relocation bracket install
I will be installing these brackets. I have a 4 in pro comp lift from the dealer. I noticed what looks like cam bolts on the lower control arm. Do I need to remove these and replace with stock bolts ?
Old Dec 27, 2012 | 08:42 PM
Delux2769's Avatar
You may need to weld washers onto your mounts if they cut your mount for the Cam Bolts. I would suggest upgrading to Grade 8, size 9/16" bolts instead of stock bolts.
But other than that, you'll be on a much better path.
