RCV front axle shafts.....
Old Dec 27, 2009 | 02:42 PM
style_front's Avatar
Default RCV front axle shafts.....
Besides the comfort of them not binding are they stronger than the traditional U-joint chromoly shafts available? I don't expect my jeep to run smooth when shes all locked up so I don't really care about that however if it means I can safely run 40's and keep my 44 up front I can see spending the extra 500 bucks over traditional chromoly shafts. What do you guys think about these RCV's?
Old Dec 27, 2009 | 02:59 PM
GoodysGotaCuda's Avatar
Depends on your terrain, here on the rocks it would be very nice to have CV joints. When I upgrade to moly shafts, I'll be hard pressed not to spend the extra money for the CV. SOO much better design. It will also be nicer on the tires when crawling/hard wheel angles.
If your terrian is more of a soft dirt/clay, you may not find them to be as much of as advantage...
Just my 2cents.
Old Dec 27, 2009 | 04:13 PM
Suffolk JK's Avatar
Running 40s with RCV shafts your R&P will be the fuse, just so you know...
Old Dec 27, 2009 | 05:05 PM
Something is always the fuse. Being weaker than rcv shafts means only that it's weaker than rcv shafts.
Old Dec 27, 2009 | 05:45 PM
giolll's Avatar
will the rcv's in the 44's be able to handle 38?
Old Dec 27, 2009 | 05:55 PM
wiredawg_mg's Avatar
RCV has a no fault warranty so run what you want and if they break just get a replacement.
Looking at their test numbers the claim is that these axles are much stronger than regular chromo shafts and u-joints.
I have seen them up close and all I can say is WOW
Old Dec 28, 2009 | 01:41 PM
giolll's Avatar
thanks for the input....
Old Dec 28, 2009 | 01:44 PM
Suffolk JK's Avatar
Who cares about blowing up the shafts and having a lifetime warranty. They won't be liable if other stuff breaks.
Old Dec 28, 2009 | 02:18 PM
HarryHood1's Avatar
i have them on mine. I went with them for the warranty. They are really nice and glad i went with them . I would sleeve and gusset before you think about 40's.
