RE 3.5 inch lift
Old May 10, 2008 | 12:18 PM
DUBAI4X4's Avatar
Default RE 3.5 inch lift
I have installed the JK 3.5" SUPER-FLEX KIT on my JK and when I purchaed it from RE the website said
This suspension will allow the use of 35" tires.
No it does not!
The Tires rub like hell on the rear fenders and now I am going to fit 33X12.5R17 Tires
I hate RE for miss leading people
Old May 10, 2008 | 12:25 PM
Ctimrun's Avatar
I think there are a lot of people running this lift without much rub, until hard flexing. Does it rub all the time or just when the suspension is flexed? If it rubs all the time I would say it is somehow operator error, rubbing during hard flex is to be expected.
The bump stops should help prevent rubbing during flex.....
Old May 10, 2008 | 12:28 PM
DUBAI4X4's Avatar
At full flex but it did not just rub it actually ripped the left rear fender flare out of its place
Old May 10, 2008 | 12:31 PM
Marauder's Avatar
I run the lift and have no rub at all at full flex in the front or rear. Interco truxus 35x12.50x17 in
Old May 10, 2008 | 12:35 PM
hm i can fit 35's with my teraflex lift. 3 in front and 21/2 in rear. whats the backspacing on your wheels?
Old May 10, 2008 | 12:36 PM
HUNTER's Avatar
I think it may be your wheel offset. I have a slight rub at full flex in the same place.
But when I get River Raider tube fenders im going 38" with 1.5" spacers.
Old May 10, 2008 | 12:37 PM
DUBAI4X4's Avatar
1.25 inch using spidertrax
Old May 10, 2008 | 12:38 PM
the spidertrax push the wheel out an extra inch is that right?
Old May 10, 2008 | 12:48 PM
HUNTER's Avatar
If its only rubbing on one side you may want to look into an adjustable rear track bar to center the axle. I had a full Traction bar from the start. And after 500 miles To break in the gears and give the suspension the once over the driver upper control arm was rubbing the frame and the axle was off center about 3/4 in. Simple fix.
Old May 10, 2008 | 01:53 PM
Ctimrun's Avatar
Hmmm, what size and backspace are your rims? If you are running wide rims or using spacers it will cause rubbing faster than optimum backspace.
