Re-gear ???
What determines which install kit you use when you re-gear ?. Overhaul Kit, Rebuild Kit ?. I'm not going to wheel it until I re-gear it, and I would like to wait until after the Holidays to re-gear it. It will have under 2000 "easy" miles when I do it. I didn't want to spend the extra $$ unless I need to.
I've seen the overhaul kit, it has three bearings, the crush sleeve, shims, bolts and the dye for marking the gears
The overhaul kit is the cheeper kit.
I think the install kit comes with everything but the bearings. Im not sure what factors require the bearing to be replaced though, Im assumming miles and wear. I dont think its a must when you regear
