Re-Gearing Chart
got a few stupid newb questions: is the 1:1 the only ratio I need to worry about or do I also need to worry about my overdrive ratio with new gears? I have an 08 X with auto, 3.73. I'm noticing some of the rpm's are higher with the new gears than stock, I thought they were supposed to be about the same? Does 100 rpm make that big a difference in power (I know it makes a difference in gas)?
Clay
Clay
For us, since we (normally) are sure of our axle ratios, we can just go look at the current ratio and find our tire size to find the rpm that we're looking for.
For instance, 4.11 (closest to the 4.10 of our axles) on 32's shows 2805 rpm. So, go to the new tire size, 35's, and go across until you find the closest rpm to 2805 to maintain the "same" feel, acceleration, etc (4.56 shows 2845... that's the closest you'll get to 2805). If you want a little more power, acceleration, etc., then go for 4.88's or even 5.13's.
Does that muddy up the water a bit?
If you had 4.10's and stock 32's you should be about 2368RPM at 55MPH
If you swap to 5.13's and 35's at the same RPM of 2368 your going 48MPH
That is a difference of 7MPH at 55.
To actually go 55 with the 5.13's and 35's you would have an RPM of 2709.
That's not too much of a difference but it's more then 4MPH, you also have to consider that the factory speedo is off by up to 10%, so in reality your indicated speed is probably even further off.
Chris, Thanks for the offer......but I actually like it being off. As time goes by, my odometer logs less miles than I have actually accumulated.
I believe it is close to 4 mph off, really don't think it is 7 as you stated the speedo may not have been right in the 1st place. But none the less I just use my GPS if I am wanting to hit an exact speed and the speedo has been close enough to keep me out of trouble so far.
