Re lift noise
Old Apr 19, 2016 | 03:08 PM
rugahrahj's Avatar
Default Re lift noise
Installed an RE 2.5" lift about a month ago... This morning I noticed a sound whenever it sways and when I turn...it kinda sounds like a squeak...like it could be rubber from the sway bars rubbing but before I go under and break things down I wanted to see if anyone might've ran into the same issue and point me in the right direction.
Old Apr 20, 2016 | 11:45 AM
rugahrahj's Avatar
Bump. Any suggestions?
Old Apr 20, 2016 | 12:25 PM
Rock Krawler Suspension's Avatar
Former Vendor
Start spraying parts with fluid film/wd40. When the squeak goes away, you found the location.
Old Apr 20, 2016 | 12:29 PM
rugahrahj's Avatar
Thanks bro...what about white lithium grease?
Old Apr 20, 2016 | 04:11 PM
kjeeper10's Avatar
Vet Army
Big fan of Fluid film here. Coated all my suspension joints, arms, etc.
Old Apr 20, 2016 | 04:43 PM
rugahrahj's Avatar
I'm gonna have to try it....I sprayed the lithium grease and it looks clunky and white...but it did take the squeak away....fluid film it is. Thanks!
Old Apr 20, 2016 | 09:04 PM
Jeepinjim's Avatar
Check your mounting hardware, they may have loosened up, that happened to me
Old Apr 21, 2016 | 12:20 AM
sa29560's Avatar
Common offenders I've found are rear sway bar links, rear shock mounts, and upper front shock mounts.
Makes a metallic bouncing noise and it is enraging!
Old Apr 21, 2016 | 08:22 AM
Former Vendor
You need something that penetrates. lithium is good for assembly purposes but not penetration.
Old Apr 22, 2016 | 10:51 AM
gbwilliams5's Avatar
Sounds similar to an issue I had a few weeks ago. The bolt on the other side of the sway bar disconnect was loose. I was getting a clicking sound when the jeeps weight shifted
