Reading Tire Sizes...What's the difference?
I know how to read 285/70/17 and 33/12.50/17.....But what's the difference and why are tires sold in these two different forms. It's making shopping for tires difficult.
Also I know that a tire in the 35 inch category can measure 34.5 or whatever. Is this the case with the other form of measurement? can a 33/12.50/17 measure only 32.5?
Thanks, and sorry if this is a dumb question.
I don't know why they use those kind of measurements. In my theory I would say because once you install supposed "same size" tires on different size rims, the air pressure will alter their supposed "exact" height and width. So the manufactures use these numbers in a ratio.
But, to make tire purchasing easy, I always use this sheet to get the tire size I truly desire...
http://www.bfgoodrichtires.com/specs...t-a-ko/44.html
BFG, Toyo, Goodyear, etc. They all use the same measurement.
So for example, lets say you want a tire that is exactly 33 inches and 11.5 inches wide. Just find the height then width, skim your finger across and see what the measurement is -- that measurement will be the same fore all other manufactures. I promise. The only difference is tread depth, which has nothing to do with height.
