Ready for some comfort.
So I have the BDS 4.5" lift and a 2"BL running 37" Kevlars. When I had my 35's the ride wasnt so bad but I'm finding that my ride is really rough and you just feel absolutely everything. I have already aired down my tires to 30 psi. Does anyone know of a comfort ride shock or the best improvement so I can have a smoother and more absorbent ride? Thanks fellas.
may not seem like a big deal, but you may want to go a little lower on the psi....
Q: On the road, what PSI should I be running in my tires?
A: For optimal comfort and even tire wear. you should not run the recommended PSI listed on the sidewalls of your tires. Typically this will be way too much. On average for a 33" tire, I would recommend that you run your tires at approximately 28-30 PSI. For a 35" tire, I would recommend running approximately 26-28 PSI. For a 37" tire, I would recommend approximately 24-26 PSI.
yeah i run my 37's at 25 psi.. feels pretty nice... also what shocks do you have ? the standard bds one... i know they make a gas shock that is alittle better .. or maybe look into some adjustable fox shocks.. they work great! i used to have the bds 4.5 with their gas shocks rode nice.
