REAR adjustable track bar
Old May 18, 2007 | 10:01 AM
BLKRUBI's Avatar
Default REAR adjustable track bar
Ok who out there is running a rear adjustable track bar with a 4" lift? I have some questions. What brand bar are you running, just a bar or a smaller (than Skyjacker) relocation bracket or both, like Teraflex uses? Thanks
Old May 19, 2007 | 05:27 AM
BLKRUBI's Avatar
No one out there running an Adjustable Rear trackbar?
Old May 19, 2007 | 06:44 AM
RedRockJK's Avatar
I'm running a Full Traction rear adj. trackbar using the factory mounting brackets. I had a trackbar relocation bracket on the rear that came with my Black Diamond lift, but I took it off when I installed the adjustable track bar.
Old May 19, 2007 | 07:58 AM
BLKRUBI's Avatar
Originally Posted by RedRockJK
I'm running a Full Traction rear adj. trackbar bracket using the factory mounting brackets. I had a trackbar relocation bracket on the rear that came with my Black Diamond lift, but I took it off when I installed the adjustable track bar.
Thanks RedRock, so the Full traction bar with no drop brackets, correct?
Old May 19, 2007 | 08:35 AM
wayoflife's Avatar
JK-Forum Founder
I have the Full Traction adjustable rear now and while I do think it will work just fine with a 4" lift, I'm pretty sure that the new Full Traction 4" Ultimate Lift will use an adjustable track bar in conjunction to a drop bracket from the frame.
Old May 20, 2007 | 04:22 PM
BLKRUBI's Avatar
Thanks, WOL, either way, it's got to better than the Skyjacker riser bracket on there now. I was just trying to decided to whether to invest (waste) $45 on Skyjacker's fix, the brace for the bracket, or get the Adj track bar , since I planned to get the Adj track bar down the road anyway. I just don't think that I want to brace the riser bracket and leave it that way.
Old May 20, 2007 | 10:31 PM
RedRockJK's Avatar
That is correct.
Old May 21, 2007 | 04:12 AM
captsam54's Avatar
Eddie, Your not still running the 2.5 tera-flex kit.. Didn't you go the the FT, 3" lift?? I looked on your spec's, but it says your running the 2.5 kit..
I am still trying to decide on my lift, and am leaning very heavily toward the Full Traction.. 3 or 4" kits.. I like the ultimate 4, but don't know if I need that much for the 33" nitto's I am running.. I will go to 35's when these wear out..
What do you think ?? PS: sent marc. the pic's..
