rear axle issues with lift?
I just spoke to someone from the dealership, and they told me I need to weld something on the rear axle if I do a lift because it will snap?
Not sure what he was talking about but.....
I had a 3" Tera kit on my 08, and a guyy down the street bought it. As far as I know he's had no problems. I see it driving around almost everyday.
Is there really something I should be worried about? The only thingI can think of is the T bar bracket, or a relocation bracket snapping.
The track bar mount on the rear and front axle can be ripped out. There are modification kits that can be welded on. So if you put on a lift and a track bar extension on the rear axle you should deal with it. So yes your dealer is correct.
Some dealers know a lot more than we give them credit for.
There are several mfg's who make the beef up kits for the mount. I just cant remember who.
So yes in some instances you need to modify the existing parts on the jeep to make up for the new loads imposed by lifts.
Do a search on broken track bar brackets and you will find that this is a weak link on jeeps. There are weld on kits and some bolt on kits but if you put on a lift and use a track bar extension you will break the welds on the rear axle. You are changing the moment arm on the rear axle mount which increases the force which in turns increases the stress on the structure which in turn starts a fatigue crack. This in turn grows until your axle track bar is no longer connected to the axle tube.
Even if the track bar mount is a weak point and may require reinforcement, according to the poster, the dealer made it sound like he needed to "weld something if he was to install a lift". The bolt-on kits available today do not require welding so I was just saying, there's no need to weld anything to install a lift. Now you may need to weld to fix or reinforce after the fact if need be after dragging the lift over rocks, then I agree.
Not exactly. With a relocation bracket, you can have problems. The best thing is to buy an adj. trac bar, because you won't have to install a relocation bracket.
