Rear Bumper
Old May 22, 2007 | 05:45 PM
aetcmh's Avatar
Default Rear Bumper
Has anyone thoght about just ditching the rear bumper it looks like it wouldnt do to much if any if someone hit you also by taking it off looks to be an awsome place to mount my hi-lift with some 4xrac brackets
Old May 23, 2007 | 12:20 AM
degenerate's Avatar
that would make your hi-lift your rear bumper...
Old May 23, 2007 | 06:40 PM
aetcmh's Avatar
since no one else has done it heres some pics. needed a place to put jack till bumper arrives
ID:	1751   Click image for larger version
Old May 23, 2007 | 06:50 PM
aetcmh's Avatar
heres the pic again
Old May 23, 2007 | 09:59 PM
Sixgunz's Avatar
I installed my Hi Lift with the bumper on. Here's a pic
Old May 24, 2007 | 09:58 PM
aetcmh's Avatar
sixgunz thats a great idea im going to steal it doing this sat along with my RE 3.5 lift
Old May 24, 2007 | 10:01 PM
aetcmh's Avatar
bobtail thanks for the honesty wasnt to sure myself but i like what sixgunz has done this will do till i breakdown to get a bumper
Old May 24, 2007 | 11:41 PM
Sixgunz's Avatar
Thanks! You're gonna need 3" carriage bolts to mount the jack & have enough room for wing nuts & pad locks. You're also gonna need 4", grade 8, hex head bolts (& washers, nuts, etc) to put the bolts all the way through the bumper.
Also, I put two large nuts between the jack and mounting towers (it comes with one slim nut....I replaced it with 2 fat ones from Ace...it spaces the jack out enough for clearance) If this sounds confusing, it'll make more sense once you're installing it. But, basically, you push the carriage bolt through the top of the mounting tower & tighten a nut on the other side (which would be against the jack). I just put two fat nuts on here for space.
Take a Dremel tool & grind a small area on each end of the 3" carriage bolt. Once it's flat, then punch & drill a hole through for the padlocks.
Give yourself at least 2 - 3 hours for this (assuming you have all the hardware at hand).... also, keep in mind that once those carriage bolts are seated, they stick straight out. Make sure they're aligned with the holes in the jack..... don't ask me how I know this.... This whole ordeal took me forever to do....but that's how things go, ya know?
