Rear CA Question
Old Oct 23, 2010 | 06:13 PM
nukeman's Avatar
Default Rear CA Question
I currently have OEM rear CA's, and Currie fronts. I would like to get my rear wheelbase centered to alleviate the slight rubbing just above my pinch seam.
Which rear CA's should I buy first to do this? (uppers/lowers).
Old Oct 23, 2010 | 06:15 PM
nthinuf's Avatar
You have already trimmed the pinch seam, correct?
You will need both sets of ca's to move the axle. One set will only 'tilt' it for caster/pinion/driveshaft angles. (though I suppose the uppers first, since you will go longer on them to tilt the pinion up in-line with the tcase?)
Old Oct 23, 2010 | 06:34 PM
nukeman's Avatar
Yep, trimmed the rock rails and pinch seam, but still get some minor rubbing above the pinch seam with the 37's.
