rear coil spring isolator
Old May 5, 2012 | 07:50 AM
the_cuse420's Avatar
Default rear coil spring isolator
I recently put a 2.5 bb on my jk, and ever since my rear end has been rattling whenever I go over a bump. What could be the cause of this. Im thinking the pig tail isn't seated properly. Any suggestions?
Old May 5, 2012 | 05:46 PM
TAIL RATED's Avatar
that's the first thing I would check. make sure it's seated properly.
what manufacts did you use on your lift. may help to determine if it was a coil lift, spacers lift, etc.
I used JKS spring reatiners on the bottom of my rear springs. they just hold the spring in place/ not isolate though.
