rear control arms?
Old Aug 27, 2010 | 11:10 AM
stevedolce's Avatar
Default rear control arms?
i get the whole front lower control arm thing, but what do i need to know about the rear? what's the proper rear caster setting?
do i need upper or lower first?
thanks
steve
Old Aug 27, 2010 | 11:29 AM
Pluke the 2's Avatar
Steve,
We need to know what you are running on your jeep as far as suspension to help answer your question.
Old Aug 27, 2010 | 11:30 AM
opdsgt's Avatar
Nothing overly scientific about it, actually.
You'll want uppers on the rear, you'll adjust them to a length shorter than that of the factory pieces, and you make said adjustment(s) until your pinion and drive shaft share the same angle (or close to it).
I like JKS controls arms best of all the options available. No jam nut to back off, and the fine pitch thread offers a high degree of adjustability. JKS arms are greaseable, hell for stout, and are art like in construction. Plus, they're a small town shop in Nebraska; I like supporting the industry under dawgs (ahem).
Note: It might be a good time to invest in a good aftermarket adjustable track bar too (again, I'd recommend JKS). That eliminates a frame mounted drop-down bracket if you're running one, and prevents track bar/passenger side bump stop interference (as you rotate the diff, you make it more likely a stock TB will touch the BS and you put an unnatural bind on the TB itself).
Old Aug 27, 2010 | 11:50 AM
stevedolce's Avatar
Default running
i'm running a 2.5 TF BB with stock springs and OME shocks. if i upgrade springs to the OME kit, will i need to work on my real control arms?
so if i'm understadning this correct, i get new read uppers to shorten(??)) the length and align the pinion?
Old Aug 27, 2010 | 01:11 PM
Mark Doiron's Avatar
If you're still running that 2.5" BB in your profile, you're okay without doing anything to the rear. If I were in your shoes, I'd be looking at a better lift before other suspension mods (perhaps a 2.5" coil). Then I'd install front and rear track bars. If you don't wheel and if you're okay with where your tires are tracking, then spend your money on something else.
(Edit: If you're running a rear track bar bracket to get your tires tracking, do as Under Dawg suggested and get an adjustable rear track bar.)
Old Aug 27, 2010 | 01:18 PM
roadking54's Avatar
Northridge installed my OME HD LT kit, and I just added TF adjustable front lowers....and it rides GREAT!
Old Aug 27, 2010 | 01:56 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Add the #1654840 TeraFlex rear uppers and those will allow you to adjust your rear pinion.
