Rear control arms
Old Jun 5, 2014 | 01:18 PM
PAGary's Avatar
Default Rear control arms
I put on the Metal cloak 2.5" lift and have a slight driveline vibration between 50-60 mph. I want to adjust the rear pinion angle and not sere if I should get the uppers or lowers first?
Old Jun 5, 2014 | 01:51 PM
Roryslife's Avatar
Uppers
Old Jun 5, 2014 | 02:03 PM
14Sport's Avatar
Originally Posted by Roryslife
Uppers
x2. Uppers for the rear.
Old Jun 5, 2014 | 02:41 PM
nthinuf's Avatar
Doesn't matter, they do the same thing.
Uppers will be lengthened a bit over stock, tilting the top of the housing back.
Lowers will be shortened a bit under stock, tilting the bottom of the housing forward.
Some people prefer the lowers, since they are beefier than the stock arms and should handle impacts better. Other people prefer the uppers, since shortening the lowers will give a slight decrease in wheelbase.
But generally, front lowers and rear uppers are considered to be the ones to go with first...
Old Jun 5, 2014 | 03:41 PM
PAGary's Avatar
Ok, then it makes sense then to go with the uppers to lengthen rather than shorten the wheel base.
