Rear driveshaft angle?
I have about 3.5 inches lift from my BDS system and I wondered about the angle of my rear stock driveshaft Do I just lenghten the top control arms to soften the angle from the dif to the shaft?
If so will that inturn make the coil springs want to fall out from them being twisted a little.
Also a guy to me I would not really need to cut anything off my rock rails that are about a half inch from the front of my rear 37's because by adjusting those control arms about a half inch that will push the rear tires or axle back a bit.
ANY INPUT WOULD BE HELPFULL THANKS ALOT
Anyone have any imput?
If so will that inturn make the coil springs want to fall out from them being twisted a little. Also a guy to me I would not really need to cut anything off my rock rails that are about a half inch from the front of my rear 37's because by adjusting those control arms about a half inch that will push the rear tires or axle back a bit.
on setup we did have to lenghten the upper rear control arms to make the pinion shaft and the drive shaft in a straight line (that is if you are running a cv joint driveshaft). And doing this will not make his springs pop out at all. I can definatly say my buddy has flexed it to the fullest and no problems their! in three weekends I will be going to URE in NC to try it out myself as I am in Iraq right now. I hope this helps
i have a 2dr with a 4.25 inch lift and and all you need to do id adjust the pinion angle where its good with the driveshaft and cut and re-locate the rear spring perchs and the coil spring will go back to normal. i did it and its not hard to do.
Currie has the weld on "perches" for the springs...
http://www.currieenterprises.com/CES...6.aspx?id=3126
