Rear FT Trac-bar rubbing on spring
Old Mar 27, 2009 | 01:55 PM
moblur's Avatar
Question Rear FT Trac-bar rubbing on spring
A few months ago I put on a 3" FT Ultimate lift on my 4dr Rubicon. For some reason the rear trac-bar rubs on the right rear spring. Everything else is fine with the lift and all the measurements seem correct. It's almost as if the rear spring diameter that was supplied with the lift is too large or the bend in the trac bar is incorrect.
Has anyone else encounter this problem?
In the pic you can see where the bar has rubbed off the coating on the spring...
Thanks,
andrew
Old Mar 27, 2009 | 01:57 PM
Piginajeep's Avatar
chances are your lower control arms are to long. It'll happens. Mine did the same until I shortened them. T
Shorten the lowers and change your pinion with the uppers
Old Mar 27, 2009 | 02:08 PM
moblur's Avatar
I thought that at first as well about the lowers but they are turned all the way down.
Old Mar 27, 2009 | 02:20 PM
Northridge4x4's Avatar
Sponsoring Vendor
Your trackbar is installed backwards. Heim joint to the axle.
David
Old Mar 27, 2009 | 02:27 PM
Piginajeep's Avatar
David
damn good catch!
Old Mar 27, 2009 | 02:33 PM
moblur's Avatar
AHhhHA...... DAMN! Thanks! At least it's an easy fix.
