Rear locker/lsd
Old Dec 28, 2012 | 10:23 AM
B 1000's Avatar
Originally Posted by Dynatrac
The Detroit Locker is a great product for a rig that sees a lot of time off road but isn't always the best choice for a DD. Rigs with AT trans are effected much less by the lock/unlock action of the locker. I have run them for many years and they are perfect for what I do but some find them a bit 'twitchy' for DD use.
The Truetrac is a great choice for the moderate wheeler that sees a lot of DD time. The traction is far superior to any factory offering and is great in ice and snow. They're a great off road diff if you're not lifting tire frequently (for pretty much anything but rock crawling, they're pretty damn good). I have them in my current DD (5 years) and ran one in my old DD Cherokee. I was a beta tester for Tractech's (Detroit Locker's parent Co. now owned by Eaton) when the Electrac was developed. It was a Truetrac to full lock 12V electric selectable. I ran them in my well equipped CJ. They were a great locker and the Truetrac function was very, very capable off road. The Truetrac is a gear driven LSD that never needs a rebuild and doesn't require special fluids. There are no 'wear' parts.
Regarding the off topic lockers suggested, the Auburn Ected SOUNDS like a great option but lacks in function. The LSD portion is clutch driven. Clutches wear out as most know if they have ever had a factory Trac-Loc. If a single tire is allowed to free spin it is wearing the clutches. The Ected locks by adding pressure to the clutch pack to achieve 'lock'. The 'lock' function can be overcome by a large torque load or worn clutches. Additionally, the side gear design adds uneven loads (in the unlocked mode) to the axle opposite the ring gear and stripping the axle shaft splines is not uncommon.
The Eaton ELocker (Dana 44 and 60) is a 2 pinion selectable compared to a 4 pinion design used in both in the factory Rubicon locker and ARB. It is not as strong as the other units and should really only be used by very moderate wheelers. Aside from the inherent pinion design weakness, the ball ramp actuation method allows the unit to go from lock to unlock to lock when the rig is rocked. This motion is known to destroy the locker quickly under the right conditions. Dana 30 and 35 models are much different than 44 and 60 models and have 4 and 3 pinion designs, respectively. The ball ramp systems highly revised and don't suffer the same issues as larger models. They are both highly capable selectables that can be considered for any application.
Well that was rather helpful I didn't know that about the ECTED MAX locker. Just curious on what your opinion of the OX locker is. I know it's an "off topic suggestion," but you seem like a good source of information
Old Dec 28, 2012 | 10:38 AM
atc22's Avatar
running a truetrac up front only for now but I love it and cant wait to get one for the rear!! My jeep is my daily driver and I only wheel occasionally. I have video of my jeep coming out of some mud and you can see the truetrac working.....I have never had any issues on the street with it. I highly recommend it for a daily driver if you dont want to drop thousands on some ARBs. Who wouldnt want ARBs front and back..... unfortunately my wallet isn't fat enough.
Old Dec 28, 2012 | 10:51 AM
backcountryislife's Avatar
Is it likely to find a working rubi locker?
I'd think someone who replaced theirs for an ARB (I've heard a few guys doing that) would sell them pretty reasonably?
I suppose what I do is pretty crawly... but the limiteds I've wheeled with might as well have been open, as they were pretty useless. I would have spent my money on increasing flex to keep wheels on the ground instead of a limited diff but like dynatrac said it's got to do with what kind of wheeling you do of course, I'm sure the truetrac does well on most trails... it's a pretty darn cool design anyhow!
Old Dec 28, 2012 | 11:01 AM
Bonedoc's Avatar
I wore out my factory LSD and replaced it with a Grizzly locker. I have to say it is a little querky at first and is definately not as smooth on road as the factory LSD but with that said, you do get used to it quickly and I don't even notice it anymore. Mine is also a daily driver and I have the 6spd which generally makes them noisier with the locking and unlocking. The performance is great and it is solid, even when lifting a tire off the ground you won't even know it.
Old Dec 28, 2012 | 12:09 PM
Dynatrac's Avatar
Sponsoring Manufacturer
OX has been working to make their locker a bit more friendly. I've always found it to be brutally strong but a bit slower to react than some of the other selectables. Getting a quick and easy torque release can be a challenge. Compared to an ARB, even the factory Rubi locker is very slow. One thing is for certain, the current ownership of OX is working very hard to overcome previous perceptions of both the product and service. I think we'll be seeing more OX lockers used as these guys are dedicated to our market.
Check here for more locker info-
Project-JK.com - Jeep JK Wrangler Resource » Dynatrac Presents - Lockers 101
Old Dec 28, 2012 | 12:53 PM
suicideking's Avatar
My mod shop recommended an Eaton. He did mention though that I might want to wait because they're releasing a new version sometime in the first quarter. Any idea if it will address the weaknesses?
You can't use the Rubi locker in an non Rubi D44, so that would require an axle swap for Sport/Sahara owners. Not a bad option if you can get a good deal on a D44 in good condition for cheap.
Old Dec 28, 2012 | 12:58 PM
Dynatrac's Avatar
I'd wait until it was released before I would believe any ETA they suggest. They are notorious for being late.
The new model will be very similar in design to the D30 version. It should be a great new option.
Old Dec 28, 2012 | 05:13 PM
5150cliff's Avatar
I really appreciated the explanation of the E-Locker you provided. I'm the one who recommended the unit to him. I have the E-Locker in the rear (44) and am now paranoid!! I was told when it was sold to me that it was a very capable unit. Now I am doubting.....almost wish I hadn't read your reply! Thanks for the good info though.
Old Dec 28, 2012 | 10:15 PM
So what would you recommend for a rear D44 that is selectable? It is my daily driver, but when I wheel, it's often on rocks.
I want to get something that is going to last a long time and do what it's supposed to do.
