Rear locker woes
Old Mar 30, 2008 | 08:48 AM
jeepfreAK's Avatar
Default Rear locker woes
I run 35's and 4.88's on my Unlimited X with factory rear locker. I got hung up in a mud hole on Monday, but was able to get out of it by rocking it back and forth (manual tranny). My locker was engaged and I was in low range. Every thing seemed great until i tried to unlock the rear locker. The locker indicator light on the dash is on a constant slow flash. I can lock the locker and it becomes steady on. Does the constant slow flash indicate a broken locker? I am planning on taking it to the dealer soon. Also this thing has been flashing for a week now!
Old Mar 30, 2008 | 09:10 AM
jeepfreAK's Avatar
Not many people know about the package from jeep. It is possible to get a real locking rear diff and electronic front sway bay disconnects from jeep for $1500 on build sheet. The locker is push button engagement in the same spot as the rubicon.The two come together and cannot be ordered seperately. Cool huh!
Old Mar 30, 2008 | 11:44 AM
adaycj's Avatar
The blinking means that the locker is supposed to be disengaged, but the signal that it is has not been sent (or received) that it is engaged. Do a sharp turn on a flat surface and feel if the locker is engaged. Also inspect the wiring harness to the diff.
Hopefully it is just a switch issue in the housing or a wiring issue outside of it. Hopefully the dealer won't be fussy about your bigger tires.
Old Mar 30, 2008 | 02:54 PM
Buster's Avatar
same thing happened to mine.
fixed under warranty $1200. Now I'm considering getting an extended warranty incase this keeps happening.
Old Apr 4, 2008 | 01:11 PM
jeepfreAK's Avatar
bumpity bump
Old Apr 4, 2008 | 01:15 PM
zerodown's Avatar
kind of off topic, but do you have any pics of your rig?
Old Apr 4, 2008 | 01:17 PM
jeepfreAK's Avatar
I can try and throw some up tonight.
Old Apr 4, 2008 | 01:26 PM
montejeep01's Avatar
$1500? damn. thats what i paid for 2 arb's add 150 for R.E. discos. never a problem with arb.
Old Apr 4, 2008 | 07:45 PM
captjay's Avatar
i am hearing that the sahara unlimited has the locker setup for arb inside the dif, u just have to get i beleive the vent tube and air selonoid and compressor. how true that is not sure, i have a budy who is going to rip his open and take a peek. i have been searching for specs and no one seems to know truly what are on these jeeps. supposedly i have some kinda package with 4.10, 35 fron, 44 rear with a trailer hitch factory welded, but i am hearing same thing on the locker deal in others than the rubi
