Rear lower control arm and driveshaft relation question.
One quick question...
When lifting a JK, the rear axle seems to want to move forward a little bit due to the fixed control arms. A way to fix that problem is to get adjustable lower control arms.
Here is the question...
Since you are now re-centering the rear axle, does the driveshaft itself "extend" the 1/2"-1" you need to re-center?
first off, you only need to extend your rear lowers about an 1/8" inch to compensate for a 3"-4" lift. needless to say, it's really isn't that much. and, being that your driveshaft actually compresses the taller you go, extending your control arms would help bring it back to where it was.
actually when i get my teraflex arms i will be moving the rear axle back as far as i can. i believe it will be close to 2". and if you look at the rock krawler stuff they say it moves the rear axle back a 1" i think.
you can do this but you have to remember that the adjustable end should be threaded into the arm 5 to 8 threads or the thickness of the end. this way you have a good bite on the end.
i have to wait to get them but i think i might set them up to where i want them then put a tack weld on the jam nut and arm itself to keep it from backing out.
that's what i have mine set at and i'm running 37's. anymore and you will have other issues like your track bar hitting your coils or your tires hitting your rear bumper and back of your fender wells. oh, i should mention that i have my pinch seam corners cut off. however, i was running 35's like this and without any problems.
It just "looks" off. Why I thought it would've been a bit more. Since I hacked the fenders and pretty much have flat fenders, I HIGHLY doubt I'll go any higher than what I am now. I am damn sure I can stuff 35s with no problems, even with full flex. Should I get fiexed, longer, arms or just go adjustable and get it over with.
well i am not worried about the rear bumper as mine is no where near the tires....
and actually i have a good bit of space to the track bar. like i said i want to take it as far back as possible, that would be one of the limiting factors. actaully at full flex my passenger side coil rubs the gas tank!!!!
here is my bumper... sorry only side shot i have with the 35's
when you do it, let us know how far you could go before it becomes a problem. i really would be interested to know
