Rear sag, hate it...help me on ideas
Old Sep 20, 2012 | 06:23 AM
Ryan0260's Avatar
Originally Posted by BarRegular
No heavy bumper, no hard top yet either. Full spare but Ivthought from what I read it was a decent lift. It rides great, just wish it wouldn't have a rear lean.
Throw a bumper and winch on the front. That should get you level
Old Sep 30, 2012 | 06:16 AM
BarRegular's Avatar
So, Rough Country sent new rear springs, I think it's worse. Can I add spacers? How high without any danger to vehicle on top of 2.5's? It looks like I'm down 1.25 in rear...thanks
Old Sep 30, 2012 | 07:29 AM
Ryan0260's Avatar
I would drive it a while and allow it to settle, especially the front. I'm may end up leveling out some on its own. But yes you could add spacers, but I wouldn't go over 3/4" of an inch. The best solution would to just go with a different lift
Old Sep 30, 2012 | 09:25 AM
Tonka_yellow's Avatar
Now you could just get a rear spacer or you can get new rear springs
Old Sep 30, 2012 | 11:41 AM
golfer97's Avatar
If you go new rear springs, you could always look for progressive coils over linear. Otherwise, some spacers will help level it off. But it's possible that with no heavy bumper or winch on the front, the front coils are not compressing much giving you reverse rake. A buddy of mine has a Rock Krawler lift and his front sits very high with his stock bumper. Front coils with RK are progressive so without heavy stuff on the front, the coils are barely moving.
Old Oct 1, 2012 | 12:20 AM
TheTerminator's Avatar
My RC 2.5" lift is also like that. In the front I got about 3" lift over stock, but rears I don't think it even touched the advertised 2.5". Maybe more like 2.3". When loaded in the rear, there is very little uptravel left on the shocks. Adding spacers in the rear might help with the look, but it won't help with uptravel. I think the best thing would be to replace the rear springs with taller ones, but not sure how that would work if you keep the RC front springs. The fronts are great and I have no complaints. They don't sag even with a steel bumper + winch.
Old Oct 1, 2012 | 01:48 AM
Hskr4x4's Avatar
I had the 3.25 lift and it was pure junk. Rear sagged to hell at 2" with stock bumper and OEM carrier holding 35s. I called and switched out coils and had exact same issue. Now I have carrier and bumper and switched to TeraFlex rear sway links and I got half inch (the way rough country does it, it's limited) You will also see better ride quality from rear. I'm now going TeraFlex 3" lift, just need to install coils and I'm done
