Rear seat squeaking
Old May 7, 2009 | 01:57 PM
powerlifter's Avatar
Default Rear seat squeaking
Took it back to dealer and they blamed the after-market lift of course.
So I'm on my own trying to figure out where this weird squeaking noise is coming from. It's in the rear seat area somewhere, because when driving it's noisy, unless someone sits on the seat, then it's gone.
anyone had a similar noise?
Old May 8, 2009 | 03:53 PM
anyone had this squeak? it's driving me nuts...
not the noise, but my girlfriend bitching about it every time she rides w/me.
Old May 8, 2009 | 05:35 PM
Mariner's Avatar
forget the hinges, spray the girlfriend and move to the front seat.
Old May 8, 2009 | 06:02 PM
chefgotti's Avatar
i thought i was the only one. i have had my jeep in to the dealer 3 times already and no luck. the only time it doesnt squeek is when someone is in the back seat. it is driving me nuts. let me know what you find out because the dealer i go to is retarted.
Old May 8, 2009 | 06:10 PM
paramaniac's Avatar
i have the same squeak. have been unable to isolate the source. im gonna try the silicone on the hinges and see how that works out. ill report back with some results
Old May 8, 2009 | 06:17 PM
hahaha
mine is too. they don't have any clue what it is.
Old May 8, 2009 | 07:30 PM
rjhoop's Avatar
for all of ya i think i figured mine out!!!!!!!!!!!the e-brake cable!!!mine did it and it drove me nuttttssssss.....it didnt do it on compression though so bouncing on the jeep didnt help me pin point it, finally i got under it over the weekend and started lifting it (bench press drivers side)and sure enough there it was. the e-brake cable had upwards pressure on it and the lever where it enters the back of the caliper would squeak on the side!!!with a passenger in the back the suspension never rebounds enough to hear it..i un hooked the e-brake cables from the top center of the frame and the squeak was gone!!!!
Old May 13, 2009 | 01:29 AM
WOW, I like all of you have this same exact problem
...and have been trying to figure it out for months.... I would have never guessed it's an E-brake issue. I will have to check it out this weekend! Thanks!
Old May 13, 2009 | 03:29 AM
pagoda's Avatar
I have to know WTF does a lift have ANYTHING to do with a seat being squeaky?
Old May 13, 2009 | 03:47 AM
wayland1985's Avatar
There's less gravitational pull the higher you go... so the seat isn't as firmly placed when you raise the jeep 3 inches.
