Rear shock orientation?
Old Dec 24, 2009 | 09:17 PM
Hellbound13's Avatar
Default Rear shock orientation?
Anyone know the rear shock orientation? Does the can go towards the top or bottom? Does it depend on the shock?
Old Dec 24, 2009 | 09:38 PM
wayoflife's Avatar
JK-Forum Founder
depends on the shock. some need to be mounted can side up and others can side down. you can't really go wrong as most come with bar pins pre-installed and they'll determine where it needs to be.
Old Dec 24, 2009 | 09:40 PM
The Skyjacker Hydros did not come with the bar pin. Two people mentioned they should be can side down, but I just wanted to be sure because other shocks Ive seen on the JK all appear to be can side up..
Old Dec 24, 2009 | 09:42 PM
wayoflife's Avatar
JK-Forum Founder
the skyjacker hydros need to be installed can side down.
Old Dec 24, 2009 | 09:43 PM
Thanks. If three people say can side down Im good with that!
Old Dec 24, 2009 | 09:45 PM
wayoflife's Avatar
JK-Forum Founder
hydro shocks are old school and need to be installed can side down.
Old Dec 24, 2009 | 09:46 PM
Gotcha. So is it a general rule that most hydros are can side down and nitros are can side up?
mkjeep's Avatar
Can side down on hydros.
Old Dec 24, 2009 | 09:47 PM
mkjeep's Avatar
Most nitro's can be mounted either way unless stated differently on the shock itself.
This end up ^...... such as that
Old Dec 24, 2009 | 09:48 PM
Makes sense since they are charged I guess.
