Rear Spring help.?
Make sure the correction wedges are turned the right way and seated properly. You can also add Teraflex 1/2" spacers on the top of the springs which have the built-in spring retainers. Lower spring retainers are also an option and many companies offer them. Your springs shouldn't come out when fully drooped if the lift is installed correctly.
The wedges are in correctly to. Fat part to the rear. I need to try a flex again and see if it happens again. its possible that in the beginning i didnt have the upper seated when i sat the jeep back down.
When your springs fall out of their perches, it's usually because your shocks are too long. The shocks are what holds the springs in while flexing to full extension. the solution to this is to: use shorter shocks, use a higher lift, or use spring retainers.
Yah thats what ive learned so far. Other fellas are telling me the lift is installed wrong. I think lower spring retainers or hose clamps will do me just fine.
Just a heads up on the spring retainers. They'll work fine as long as your shocks are only a little too long (0-2 inches est.) Any longer than that and the spring retainers will cause your springs to over stretch and damage your springs. It's all about balance.
and i havent looked into limitting straps as of yet
