Rear suspension issue - trackbar
Old Jul 29, 2011 | 04:45 AM
renpia's Avatar
I had this issue with a 4" Procomp lift also. The RK correction wedges fixed it for me. $25 cheap fix.
Old Jul 29, 2011 | 04:45 PM
aermotor's Avatar
As I said before, rotating the trackbar will do nothing to fix the issues. I would get the Evo Plush Coils instead of whatever you have. They are 5" wide and feel incredible!
Old Jul 29, 2011 | 05:03 PM
Scott08X's Avatar
Think that's the route I am going to go with thinner coils. I measured mine and they r like 7 inches so I think a thinner coil and spring perches will do the trick. Thanks for all the help!
Old Aug 3, 2011 | 01:11 PM
Andrew@EVOMFG's Avatar
Sponsoring Manufacturer
EVO MFG Representative
The Outside Diameter of the rear EVO Plush rides coils are just a hair over 5".
Old Aug 3, 2011 | 01:32 PM
TX_Dave's Avatar
Have you trimmed the pinch seam? Just cut that protruding corner off, or bend it over with a big hammer.
Old Aug 3, 2011 | 02:23 PM
Rock Krawler Suspension's Avatar
Former Vendor
Small bodied coils should do the trick for you like we offer.
RK
Old Aug 3, 2011 | 04:17 PM
renpia's Avatar
The pinch seems have nothing to do with this issue. The pinion angle due to the lift is causing the coils to bow and interfere with the TB. He needs to correct his coil perch angle with correction wedges or weld new ones on.
Old Aug 3, 2011 | 04:49 PM
Scott08X's Avatar
I ordered RK 3.5 in coils and their correction wedges. Just waiting on the parts. Should correct my issue.
Old Aug 3, 2011 | 04:50 PM
Scott08X's Avatar
RK
Just waiting on your parts Heard the 3.5 coils were out of stock till next week or so
