Rear Taillight wiring HELP!!!
Old Sep 18, 2013 | 08:43 AM
THE HULK's Avatar
Default Rear Taillight wiring HELP!!!
Hey guys, in the middle of installing Poison Spyder flush mount Led taillights and back up lights and having a problem... I wired the passenger side taillight and back up light as the diagram states but when it comes to the drivers side there is a a bunch of wires that are different. I figured some went to the tow harness but then there are the others. I have hooked them up but when and only when I turn on the drivers turn signal nothing happens. Only when I turn passenger side turn signal on both lights blink??? Can someone please shed some light as to which wire will make the Drivers side blink?? Thank you
Old Sep 18, 2013 | 09:13 AM
Mark Doiron's Avatar
You might check out the first post in this thread about how he ended up wiring his lights up (scroll down past the mechanical install). That is what I used (several installs on different Jeeps) and it worked like a charm. He alludes to the fact that there is some misinformation out there about getting these properly wired up. Hope it all works out for you!
https://www.jk-forum.com/forums/jk-w...nstall-107819/
Old Sep 18, 2013 | 03:10 PM
THE HULK's Avatar
All done.. I gotta say, coming from a muscle car background these Jeep Canbus wiring is fricken ridiculous.. You would think that that the wires on one taillight would be the same damn color as the other side!! Nope.. I know I could've checked it with a tester but come on now some the same some different and the same ones do different things... Any how.. Just ranting.. All is done. Thanks
Old Oct 8, 2013 | 07:35 AM
TaylarsJK's Avatar
How'd it come out? Never seen a gecko jk with crusher corners
Don't tread on me.
