Rear trac bar problem FT-3in lift
Old Mar 30, 2008 | 02:54 PM
G Timmy's Avatar
Default Rear trac bar problem FT-3in lift
I put the FT 3in lift on today and I have a wierd noise coming from my rear trac bar bracket. the bracket will not stay in one place there is a gap between the bracket and the factory mounting point. so when I go around a corner left fast the axle shifts to the left and the inside of the tire rubs on the swaybar links.
that is the only thing I can see rubing and the only thing I can think of that is happening.
so Who makes a better bracket, cause I think I'm going to order a new one??
Old Mar 30, 2008 | 03:01 PM
riverzendz's Avatar
Get a FT rear adj. trac bar and ditch the bracket?
Old Mar 30, 2008 | 03:02 PM
RESCUEJPF's Avatar
Default Bracket
If you are using a relocation bracket my opinion is toss it!! Get an adjustable track bar......... My dealer said that the brackets are what is breaking the mounts off the axle housing
