JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Rear track bar mount broken!! (https://www.jk-forum.com/forums/modified-jk-tech-2/rear-track-bar-mount-broken-266473/)
RedFox Mar 3, 2013 05:03 PM
1 Attachment(s)
Attachment 429294
So I was casually driving the other day and heard a loud thump. My rear track bar mount had broken off the axle!! It broke due to the added leverage of the lift kit it had installed on it (a simple bracket that attached to the oe mount to raise the mounting point),
Any suggestions for a replacement? I'm thinking of calling up offroad evo tomorrow to get it done as well as adding rock skins and maybe sliders..
jaker t5 Mar 3, 2013 05:13 PM
Mine did that to , first welded it back up and broke again
Second time grinded off the stock mount and custom made a mount been good ever since
There are a few company's that make some nice ones off the top of my head metal cloak has a sweet one
Atch Mar 3, 2013 06:16 PM
Can't tell for sure from the pic, but you can try and use a trackbar relocation bracket like what EVO offers
Smashboogie 4x4 Mar 3, 2013 06:33 PM
This is a common problem. You will find some lift companies producing a track bar with a bracket that will be bolted to and surrounding the stock mount. At that point you also weld the relocation mount axle to prevent that from happening.
Here is a picture as an example.
RK Rear Track Bar Mount
Justinn407 Mar 3, 2013 07:47 PM
1 Attachment(s)
Attachment 429416
Here's a pic of my new Artec truss and track bar bracket.. Good stuff.. Bomb proof..
Steeperjeeper Mar 3, 2013 10:13 PM
The same thing happened to me driving from Maine to Va but it was in the front track bar bracket.
lkjk Mar 4, 2013 06:11 AM
Is this a common problem due to the relocation bracket or even with adjustable trackbars and no bracket?
kjeeper10 Mar 4, 2013 06:17 AM
1 Attachment(s)
Mounts like Teraflex have additional mounting spots,
Track bar mount/axle and lower control arm bolt.
I believe they only require welding if doing extreme off roading.
chris@offroadevolution Mar 4, 2013 07:41 AM
its common with a bracket designed like whats pictured, Give us a ring!
RedFox Mar 4, 2013 11:12 AM
Originally Posted by Justinn407 (Post 3457613)
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=429416"/>
Wow, I really like that. I might end up going that route, looks sturdy!
© 2026 MH Sub I, LLC dba Internet Brands
